glanza ep91 23
    146
    Ireland
2366 profile views
glanza ep91 23's Achievements
  1. I was looking at the online Toyota epc parts catalog and I am unable to find the wiring pins and rubber grommets for connectors pins and some of the connectors themselves. Is there part numbers available for these items or a website where I can source these parts? Thanks
  2. I am removing the steering column from an EP80 starlet and I am just wondering can the steering column be removed without taking out the dashboard ? If so how do i remove the column with the dash in place.Thanks
  3. Ya there just a small bit of play in it when i fit the driveshaft and tighten the nut ill see thanks
  4. hi i install a wheel bearing and the bearing split a few times is that normal? And ive installed the hub plate and there a small wobble is that ok?
  5. What grease do i need to lube the front hub bearings with?
  6. Hi i put in a new brake master cylinder and ive to swap the plug but i dno which wire to connect to the oem plug?
  7. Hi i three bolts left do they just thread in or am i missing something
  8. Ya tried that ended up taking the head of the bolt off now im wondering will i cut the dust plate at the lines drawn or leave it off
  9. Basicaly i cant get the bolt out its spinning. So will i cut the dust plate along the lines or will i just run without it
  10. Hi i broke the 10mil bolt that hold on the dust plate and now im wondering can u run a manual without one thanks
  11. Ya i know the dizzy one its the one that snapped off im not too sure of
  12. Hi im wondering what is this plug for and also where can i get a replacement thanks
