Madge1980
    71
About Madge1980
  • Birthday 12/09/1980
    Staffordshire
    Many, all unrelated :-)
1548 profile views
Madge1980's Achievements
  1. Bonnet off, few pipes and plugs off, exhaust off, drive shafts out, bish bash bosh haha. Not too bad of a job if you have access to a ramp or engine hoist. I have a hoist you are more than welcome to borrow if your local to Stoke.
  2. The one I used dude was a QH belt, part no QBR4913. Hope this can be of some use
  3. Yes it's predominantly a swapping site. I thought you said your were after a p/x, my mistake. Good luck with the sale though mate she looks a good one
  4. Have you tried listing it on swapz? I have had mine on there for a while now and had some really tempting offers (and some shite ones). Maybe worth a try and it's free.
  5. Hi can anyone tell me if a short route hot pipe will fit with the standard intake pipe to the turbo still in place?
  6. Could you go straight into the loom by the ecu?
  7. OK brilliant thanks for the reply bud
  8. Finally finished plumbing in my Avcr today, took it out for a test drive and noticed a clicking sound coming from what sounds like to be the solenoid when whenever I start hitting boost. Is this normal or is the solenoid faulty?
  9. Just in case anyone else comes across this, just wire it in as the diagram says!!
  10. I put 3 different rocker cover gaskets on mine, they were supposed to be OE quality ebay items but they all leaked. I then went and bought one from Toyota and it's been perfect ever since.
  11. Just bumping this up again, I know not a lot of people will have come across this but in theory it makes sense. Are all MAP sensors not the same, a positive, a negative and a signal?
  12. That's not what I wanted to hear haha, I just finished fitting my avc-r at the weekend,and I'm running a stock ct9, just got to set it up properly now. My thinking was that at least it's there for if I do ever decide to go with a different turbo set up.
  13. Good evening guys, I have wired in my Avcr this evening, I used the guide from this forum but have a query. The guide says to connect the purple wire from the avcr into pin no3 of the 26 pin plug, which according to the vehicle ecu manual is "ignition feedback from the ignitor coil" Can anyone confirm if this is correct as I have connected the purple wire into pin no4 on the 26 pin plug, which according to the vehicle ecu manual is "part of the IIA (rpm)" which seemed the correct one to me but the rpm on the avcr display is not reading correctly. Any ideas??
  14. Does anyone know if it's possible to use the MAP sensor from my A'pexi avcr to control my EMB? What I mean is can I use the 1 MAP sensor to control both units. Cheers for any info
  15. Sure this has been done loads but I have never come across it yet, thinking of ditching my cd player and fitting a 3 gauge pod holder (single din size) in its place rather than a pillar pod. What I'm wondering is has anyone come across Bluetooth speakers that I could use, either ones specifically designed for this kind of thing or small enough Bluetooth speakers that could be mounted under the dash where the original ones go. Then I can just play radio, mp3s etc through my phone.
