BYC-designs
    1
    Preston
918 profile views
BYC-designs's Achievements
  1. Good to see some good comments regards to my designs. As talked about with Scott it will need setting up correctly balancing the rear wing with the front splitter. Once you find that sweet spot then you can start to push past your existing limits. Alot of people find it hard to understand and ask "why fit an air foil/wing to a front wheel drive car" Well After doing many testing out on track I found it started to reduce my lap times as I was able to push harder with the more stability and down force at greater speeds. Also it takes alot of Balls to push yourself harder and faster into corners as aero don't come into full affect below 60mph. Here are a couple videos you can watch that explains alot better than me haha.... http://bycdesigns.co.uk/index.php?route=information/information&information_id=10 Thanks guys 👍
