Avinash Trance
    60
About Avinash Trance
  • Birthday 11/25/1990
    Mauritius
1370 profile views
Avinash Trance's Achievements
  1. Ohhh sorry i have not noticed that you are forged. Yes the Castrol Edge 10w60 is better. I have a friens of my Forged and running on 10w60. Best oil for this forged engine.
  2. MR-2 I was running on 10w60 Castrol Edge. Very good oil but on 4efte and stock its way too thick. When start moving I noticed its a bit slower. But Better engine protection. I think Motul 4100 Turbolight 10w40 or Castrol Magnatec 10w40 are far better.
  3. Hello mates I am a stock 4efte. I am having problems when starting my engine. When i turn the key, the engine starter starts, blocks and then the engine start turning. I notice a big Voltage down on my Volt gauge sometimes it comes down to 8v. I am NOT having this problem when cold starting only when i stop then re start. What the root of this problem?
  4. Yep...the OE filter i think made from DENSO. Am i right?
  5. Wat about K&N?
  6. Hey guys which oil filter do Glanza reccomends?
  7. Thnx a lot guys...
  8. Do u have a diagram or picture?
  9. Yes A/C and the Stock Basics
  10. Hello I am a stock Glanza V I want to install Oil Pressure and Temp Gauge. I tried to fit in the Sandwich plate but the Sensors cant fit because of tight place. In that case what can i do or modify?
  11. I use MOTUL 4100 TURBOLIGHT 10W40 on my Stock on. And yeah the Motul 4100 is a semi synth
  12. Hello Glanza V 99 engine Stock I was running on Castrol Edge 10W60 since I changed mechanic I am using Motul 4100 Turbolight 10W40 I am getting some kind of white smoke when I start moving. Is the Oil Grade or Turbo issues?
  13. Its hard to find where I am here. Where can i get it online
  14. Thanx Jamie
  15. Hi Can anyone send me Part Number for Front Discs Brake Toyota EP-91 Glanza V 99 Dimension 255mm Any brake discs available?
