Mike2016
    26
    Midlands
2102 profile views
Mike2016's Achievements
  1. on the euro car parts site says there is a 1mm difference to the centring diameter but it wouldn't be the first time they have been wrong
  2. Hello I have an SR and have bought a glanza rear axle to do a disc conversion. The glanza axle has a the abs sensors but i dont intend on using them. Does it matter what discs i run? (abs/not) Thanks
  3. So I have been offered an ep91 sportif with a 2zz-ge in it. It still needs the wiring doing so its only £1000. Is it worth buying What would it sell for once done Any advice appreciated
  4. Was gonna say if it was detachable would get a friend to blow smoke from an ecig up there lol Sent from my F5121 using Tapatalk
  5. Would still need to find the end of it tho right Sent from my F5121 using Tapatalk
  6. I was hoping it wouldn't be. Looking at the line it's empty so if it is blocked it's at the top. Any advice/suggestions on how to remove the headlining? Sent from my F5121 using Tapatalk
  7. So I have removed the sunroof and also the seal and I can't find any drain holes at all Sent from my F5121 using Tapatalk
  8. As mentioned in a previous post my sunroof is leaking now badly. It's filling the headlining on the car and water is running down the inside of both the windscreen and the rear window. I can't find where it's leaking from or how to fix it. Someone previously suggested something about drain holes for the sunroof but I can't even find any. I have a 98 sr any help would be much appreciated as I don't want my car rotting from the inside out.
  9. Thanks for the reply I was at somewhat of a loss to say the least. I'll have a look at this after work providing its not raining.
  10. Any ideas?
  11. So my car developed a leak in my sun roof which is never good. Anyway so I had the issue of water in my passenger side floor which needed to be dried. After using a towel for a while I decided to use a 12v cigarette lighter powered heater as the cars heaters weren't doing all that much. 15 mins later and the heater has stopped working and after testing with numerous devices and a power probe I can safely say there is now power to the socket. My assumption is a fuse however from what I have read that would stop the clocks radio etc from working and they are all fine. So my question is is it a fuse if so where is it located. Car is a 98 Sr Thanks for any replies in advance
  12. Has anyone used omex on a starlet in the past Sent from my F5121 using Tapatalk
  13. So I was given an omex clubman from a friend. So I thought why not fit it to the starlet just to see how it sounds. Now the one I have is relatively simple to wire since there's only 3, but when it comes to wiring the omex to the negative part of the coil does anyone have any advice as with it being an N/A the coil is inside the distributor Thanks in advance
  14. Haven't done a lot lately just wanted to add share this. More to be done when I have the money to fund it Sent from my F5121 using Tapatalk
  15. Not been on for a while due to being busy with work but managed to make some progression and finally painted and fitted a strut brace I picked up from ebay for about 20 quid. As always all comments opinions and suggestions welcome, actually wanna know what you think of the strut brace Sent from my F5121 using Tapatalk
