32 -
starlet86's Achievements
How much boost through astandard intercooler?
starlet86 replied to starlet86's topic in 4E-FTE Engine Discussions
mmm now im confused as i have two different answers, would it be ok to run 0.9bar through the standard top mounted intercooler or not?! Thanks!! -
Hi Just wanted to know how much boost i could run through standard intercooler on standard engine? All i have fitted is a BOV! Thanks
Hey people! I have had it diagnosed and sorted! It was the coil pack the was broke so i had it replaced costing me a total of £75 inc labour, diagnostics and part. Just glad it wasn't too expensive! Thanks Lewis
Checked earthing and is fine, also checked wired et and they all seem to be good! Tried getting someone to get it on the diagnostics but no1 has the adaptor and can't to it! I'm completely stumped and don't know what to do!!
Hi guys n girls! Been having trouble starting car in wet and getting missfiring etc! Went under bonnet and my king led disintegrated in my hand so for that was the problem and changed that! Unfortunantly that didnt work, car ticks over but will not start. Cleaned all the connections etc. I then tried earthing it out and it wont spark so the problem must be before the king lead! Any ideas pleaseeeeeee, i cant get to work at mo so need to fx asap! I have a starlet gt turbo ep82 1993 Thanks Lewis
rite....... Car overheated other nite so pulled over because temp gauge was up in the red and my heaters were blowing freezing cold!! Looked under the bonnet and my pipes coming from my radiator were sqeezed together not allowing and water to pass through. Not being an expert i called the RAC who came and took my thermostat out and jammed it open. It was running freezing cold then and heaters were blowing hot! Actually it was so cold it was at the bottom of the temp gauge. I then went to drive home about 20miles and about a mile from my house it shot rite up again and overheated! When he did the thermostat the rad cap was off and we could see the water flowing past so it was circulating around the engine. Another thing i noticed is when it overheated before my house and i got it home my coolant bottle had overflown. Sorry for boring you but any ideas, could it just be the thermostat needs replacing? oh and also my car is now reving itsel from 1500 rpm to 2100rpm going up and down on its own wivout me touching throttle! PLEASE HELP lol!!!!!
I have got 8k kit and they are very bright! the only problem is i cant adjust my beam angle and get flashed by loads of drivers. how do i adjust it? I have ep82 model (Not twin headlights just single) Cheers
Been given a busy week at work so going to do it on thursday morning and give it a try and let u know. As for the HKS actuator thing it seems to be doing it through the whole rev range but might invest in one neway!! Saying that it seemed fine today because i have been driving around alot as i fitted my HKS SSQV (sounds amazing!!) but i know it will do it again so going to try what i can and see what works!!!
I've checked all the pipes and they seem to be fine so hopefully its as simple as plugs, will do them 2morow and see if it works! Thanks
Rite, In the last week or so i have noticed that (sometimes) my car doesn't seem to be pulling properly. The boost gauge says its boosting at a steady 0.8bar but it doesnt seem to be pulling like it should. 1 day it will be pulling fine and if i plant it in second it will spin in the dry, then other days it wont even spin in the wet in 2nd!! It feels as if it goes a little then holds back then pulls n its kinda gently pulling then holding off! Only mods i have are: MBC FMIC Forge BOV Running 0.8bar Any help would be appreciated guys!! Thanks
why write it when somebody has done it for me lol!
Pressure builds in the engine crankcase due to vapor from the hot engine oil and from exhaust gases that escape past the piston rings. A crankcase breather system is used to release this pressure. If the breather system becomes blocked, the crankcase pressure builds internally. As the pressure increases, the oil is pushed through the area offering the least resistance, such as the dipstick or a seal. Crankcase breather filters are employed to ensure the crankcase does not become blocked with foreign materials as pressurized gases escape.
oh rite thanks people! Does the ep82 need recirc or not?
1) sx_turbo 2) Abbott 3) Turboflow 4) KW.Hurst - toyota sportif, newbie 5) Andy 6) Paul 7) Luke GT_Elaine 9) Jules-b 10) Mikey Jay 11) Riko 12) Cooch 13) Paul (Paseo si) 14) *starlet_babe* 15) D3N0 16) Ped87 17) Andy ( oh yeah ) 18) SpeedyPaseo 19) Glanza Al 20) Bullet 21) Shelly star - probably have King_Stu and Suspected_psycho in my car 22) Steely 23) Glanzamatt 24) Dan_ep82 25) Timkemp1986 26) Evo 27) Cantbassed 28) Andyb (new guy be nice) 29) Toby (maybe) 30) Glanza k-31 (Kei) 31) Chinaone 32) Luigi GT 33) Gaz 34) Briggers 35) tgtt.com (shaun) 36) Nightspirit 37) Gt Daz 38) GlanzaV1.3 39) Calvin - Old site member 40) Mirror Man (Very Possibly) 41) Papa_Nicole 42) thomllee1981 (should be there) 43) Vulcan (hopefully) 44) Blak_mamber 45) starlet3SGTE (will try and make it) 46) TIMMEY 47) montanajr- i added u you lazy git 48) Starlet86 (try my best, Bloody shiftwork!)
I ordered a HKS ssqv couple of days ago and it is yet to arrive! What does the adjustment do? didnt even know it had it. and what is stall in reference to BOV's? Sorry if im being dumb!!
