Ruddock111
    12
    Co. Armagh
1266 profile views
Ruddock111's Achievements
  1. Cheers for the help. Have to get a crack at it.
  2. The how 2 on paseo to starlet clocks was with a starlet which already had a review guage
  3. I'll have to get a look at the back of my clocks in the car
  4. Looking to put white paseo dials in the 96 starlet sportif but wondering which wire do I use for tacho pulse. As previously mentioned A6 on starlet to A10 on paseo, but according to the wiring diagram (starlet), there is no A6.
  5. I have read about a wiring from a green wire coming from the distributor and tapping into the diagnostics port. Matthew Ruddock
  6. I went through the two diagram and identified what pins are found on both clocks and outlined the changes as shown below. https://ibb.co/e2zkpv When I completed that I found that on the starlet wiring diagram the following pins are missing: A7 (Seatbelt Light) which I don’t have a seatbelt light on car so probably don’t need this. B2 (ABS Light)- don’t have ABS so probably don’t need this. C9 (Ground)- Not sure what ground this is for. On the Paseo diagram: A10 (Tacho Pulse from the ECU)- what feeds this pin as the starlet does not have the tacho All help greatly appreciated, Matthew Ruddock
  7. https://ibb.co/dLPega (Starlet N/A Wiring diagram) https://ibb.co/dDKega (Paseo Clock wiring diagram) The starlet wiring diagram as shown above what I believe to be the closest to my car. the paseo diagram is correct as I compared it the my recently purchased clocks. Can anyone help me with what wires would need swapped. Cheers, Matthew Ruddock
  8. Hi all, I am looking to put paseo white clocks in my 96 Starlet Sportif which has no rev counter. My question is, does anyone have a clock pin diagram for both sets of clocks so I can see what I have to change in regards to the pins. Any help would be much appreciated. Matthew Ruddock
  9. Hi all, I am looking for a corolla inlet manifold and a set of bucket seats. Must be able to post items. Any help would be much appreciated.
  10. Hi all, I bought a starlet T-shirt and a key ring of this website about 6 weeks ago and it still has not arrived. I have tried to contact the site but with no reply. any help would be much appreciated. Matthew Ruddock
  11. What offset do you have. The fondmetal 4000 have et24
  12. Hi all, I have a 1996 ep91 Toyota starlet non turbo and not lowered or modified in anyway. I am looking to put some alloy wheels and have found a set of fondmetal 4000 15 x 7 and was wondering would these fit my car.
