Ivan
    66
Ivan's Achievements
  1. Hi All, I am the owner of www.ep91.com domain and want to put it up for sale. I do not want the domain to be owned by the registars that charge an extorsion to buy the domain again. Price - throw me an offer Options - i have a fully owned version of VBulletin suite with maintenance (not the cheapest thing in the world) that im happy to sell off for an additional cost. The hosting is also quite reliable and cheap that im happy to transfer. Contents - i have about 300MB of data and details and images of starlets that is very useful (and quite a bit categorised). I am happy to share it all if someone knows where to put it up. CONTACT: Send me PM. Cheers, Ivan
  2. Thats only because you must have done something wrong. USE THE 5E MARKS ON A 5E BLOCK! USE THE 4E MARKS ON A 4E BLOCK! Ivan
  3. Is anyone having probs connecting now? a DB error?
  4. can be resolved by porting wastegate and getting better actuator. Regards, Ivan
  5. Alfa Romeo 147 GTA
  6. can you post the pics here?im interested in seeing this by the way, if you roll a car on its side, almost always it will damage the roof as the a and b pillars are designed to cave in certian sections which would twist the roof. Also your rear quarter pannel would be severly damaged and if that be the case, its not worth repairing. Ivan
  7. HAH! Wait for it to go drifting this weekend and you will see the S15 front end, along with a big hole in the front wing where our new cooler fits in. We make ducting for the coolers (air and oil), and have changed the ignition with bigger coils and leads and fueling has been changed aswell. Ill get pics soon Regards, Ivan
  8. Sorry to hear about it... But i must commend you on you smart repair work. It looks really good and people wouldnt even notice that the ring is there. Very nice. But when you get some more money, get the locks removed and it will look alot nicer Now onto the radiator, how big is it?...the hole? If its a small hole you can get this cement paste for steel/alloy that i have used on radiators before and it keeps the tight and fixes your problem. After using it on about 5 different radiators and not having any issues, for a small hole i wouldnt think twice. If its a bit bigger hole then yes, get a new one. Hope it helps, Ivan
  9. Ok, im not sure im quite following but from what i gather, you are doing a 5e non turboed? right? Well the inlet mani fits a 5e, we have one person in hong kong running one, and im about to run one on a 5e aswell. Although both of ours are turbocharged. If you are interested in a quad throttle body setup, we may be able to sort something out for you PM me exactly what you are building, and what you expect to achieve out of it and i can guide you into the right direction. If you are doing n/a work, then you will have to do alot of work to get some figures but you will get there with persistence, and it would be nice to see someone get some power without a turbo for a change. Regards, Ivan
  10. hahaha, busted ;) Dont pretent like you dont want it scutch0
  11. Hi, Its hard to say what gains you would have exactly as it all depends on the engine, or what modifications you have already done. The inlet manifold wil give you better top end performance and would be more linear power curve. You could run a bigger throttle too. If you are planning on turbocharging the car at any point, then its well worth it. Its the type of modification that works very well with other mods, but on its own (with a naturally aspirated engine) you might find it only helps top end and thats all. It definately would make a difference, but to what extent is the question. Regards, Ivan
  12. I love those 15's... they are a very racey kind of sex ivan
  13. Hi everyone, Well i said i would start making kits for starlets and finally we have done it. We currently have the TD04L kit, an inlet manifold and a few other bits and peices. RoadRunner is a Sydney based fabrication company that makes creations on high performance cars. They work on all sorts of cars, and all sorts of tasks. If you are from the Sydney area, RoadRunner can install most components, and can do custom fabrications aswell. From intercoolers, engine swaps, custom exhaust manifolds and wiring in computers. They do it all, and do it all very well. We are looking at expaning the different types of kits like CT9 and T25 upgrades. We will also be looking into some suspension products (braces that whiteline dont make), plug-in computers, exhaust system kits and ofcourse intercooler kits. We have all our current items listed in our own new section: http://www.ukstarletclub.com/forums/index.php?showforum=15 (thanks heaps Enzo for providing that for us) Here are some examples of the work RR does: Fernando Wiehrl's 180... There have been quite a few changes to the car so ill get the latest pics after saturday's driftday. Customers Cressida and an example of the welding Here is a quick example of what our manifolds look like: Exhaust Manifold Exhaust Manifold Inlet Manifold Inlet Manifold Thanks, Ivan
  14. SARD do not make a rising rate fuel pressure regulator. SARD make a fuel pressure regulator at a fixed rate of 1:1 i believe. Sorry, just had to clarify that one as its allways missinterprited. Regards, Ivan
  15. Yes, undo the top 24mm bolt and let everything drain otherwise the excess oil will bust your seals and possibly do more damage. Regards, Ivan
