Bolts
    11
    Australia
1185 profile views
Bolts's Achievements
  1. Anyone know how far out the mounting points are
  2. By much were would I find diagrams do you know
  3. Hey can anyone tell me if the Glanza ep91 exhaust mounting points are same as na ep91 starlet fitted 4efte to na model want to put HKS exhaust on it will it fit
  4. What about the small harness that runs out of it for the dash lights and indicators
  5. Can someone please let me know do I leave the 4efe ecu in the car when using a stand alone I'm using a link monsoon to run my 4efte in my ep91 but do I need the ecu for cabin wiring or do I just unpin the efi and map sensor and leave it there
  6. Bolts
    Link monsoon
    Great thanks for the info with that tps what's the go with the wires out the top do you use them or the tps main part
  7. Bolts
    Link monsoon
    What tps would you recommend any straight bolt up
  8. Bolts
    Link monsoon
    Really is the tps straight bolt up is it variable or open close was just going to use what is there get it up and running and replace as it fails I work for Toyota so can match with new stuff as for size and work out wiring later. What's with the wideband differences
  9. Bolts
    Link monsoon
    Really dose it have enough inputs and outputs did you wire in the air solenoid on the intake
  10. Bolts
    Link monsoon
    I have the 4efte out of a ep82 gt starlet and replaced the ep91 4efe what are some key things I should prior to the wiring up was going to standard distributor for now or should just fit cop now
  11. Bolts
    Link monsoon
    Hey I'm new here just wanting to know if any one has used a link monsoon ecu on 4efte in a standard ep91 was na now has a whistle in it's mouth
