houses
    5
houses's Achievements
  1. Engine kit T04111-11104 £109.29+ Ring set T13011-11132 £64.74+ Genuine toyota part numbers + prices for turbo vehicle , available in the UK for a 2 day stock order! Houses
  2. right then chaps unfortunatly ive been proved wrong they are not online! which means that they must be in the box with the lamps. sorry for letting you down chaps but for anymore info then drop me a pm! houses
  3. PM received. ill do it about 10ish tomorrow ummmm depends bout the availability. most of the stuff for the EP91 (accessory wise) are being discontinued. but i have the ability to check the stock at 150 other dealers so some of the discontinued stuff can still be had from dealers across the country. so if any one needs help feel free to pm me! houses
  4. yeah sure mate pm me your email address and i will send you the file tommorow from work houses
  5. Hi guys Well here goes for my first UKSC post! I'll do a write up on my car in the new members section. I am currently working in a toyota parts department for my sins! and have looked at a set of these fogs for my own vehicle. They should be pretty easy to fit if you ask the right questions when you pic them up! the system the dealer would have used to find the number is EAPM and listed with the items will be a fitting instruction PDF.so when you pick them up ask them if they would be kind enough to print of a copy. i'd imagine the toyota time to fit would be about 2 hours and would maybe invole removal of the front bumper. but if you get the instuctions then it shoul be quite easy! hope this helps houses
