peanuts
    15
peanuts's Achievements
  1. cruise are very good but very expensive ;) mine cost $550 au like the rest of the cruise stuff its pricy.
  2. yeah well done there matey interested in doing another set?
  3. heres a pic of the gaurds, unless you put another one next to it or a pic you cant really tell.
  4. ep82 mounts are differnt there for will not fit directly that i am 100% sure of hope that helps
  5. hey baz i know its abit off topic but what the colour of the one in your avatar? the black with another colour in it? sorry mate. cheers brett ps: cars looking beautiful!
  6. hey guys i ve got 215/35/18 on mine with 1 42mm offset , thou i had to pump the front gaurds and pull the inner plastic gaurd out and roll it, and on the back i am using a gt axle and brake set up because the axle is shorter in width so i havent rolled my rears and still have 4mm between the gaurd and tyre! maybe try that if you can get a gt axle. might ad that mine gaurds are down to the chrome on the back and the fronts cover half the tyre at the top. oh and if you ask about the bolt part that holds te bumpers on the back has to be bent up and be mounted a little further back and the fronts it was easyer to pump the gaurd than to modify becasue you can still use the original mounts and it looks heaps meaner from the front! hope that helps maybe you guys would like some pics? cheers brett
  7. thats so hot mate! good luck with it
  8. yeah its a factory toyota part, thou i am not sure of the part number will try and fing out.
  9. vw golf gti or peugeot 206 gti!
  10. ive got them too but with koni springs, there are a really good set up!
  11. what about the glanza v one on the rear hatch?
  12. have you guys seen the cruise front bar? www.gozocreations.com look in the cars section, sent them an email but didnt get a reply
  13. zep racing prices are very expensive, keep that in mind.
