TheFantasticG
    18
TheFantasticG's Achievements
  1. Honestly, I'd like to import the drivetrain and suspension off a 2006 Xi 4WD Avensis and convert my tC to a 4WD boosted monster... but alas, tis too much money.
  2. It's a 2AZ-FE. As a temporary fix until I get my pieces (manifold/exhaust housing on turbo) for coating I was thinking about getting a Turbo Blanket. They are a bit pricey, but a functional and can provide an additional clean look to the turbo. The PTP Blanket in black is what I am eye balling currently. So I got it in. It doesn't like to bend, so I took off the DP. Here is the pictorial results of that. And there ya go. I'll take it out during the day tomorrow to see what kind of temps I see in the rad. fluid.
  3. Thanks. In most of the gauges that have been done on tCs, you see a blue/white combo like this: or one solid color like this: I wanted something different. It turned out well. The blue to left and right of the speedo make it look even better.
  4. All modifications are on hold until further notice (i.e. buying new parts). You would too if you lost your job ;) I still have parts that need to be installed that I purchased some time ago. One of those was a Gauge & HVAC cluster LED kit. I and the North Houston Scikotics (some of them) got after it yesterday. None of us had done the HVAC before so it took quite a while to double-and-triple check/test that all the resistors and LEDs were done correctly and for me to finally decide what I wanted to do with the colors. I'm mostly satisfied with how it turned out. I need to de-paint the needles completely and leave them clear, and maybe change the blinkers to white... but that's about it. Otherwise, I'm satisfied with how it turned out. Take a look:
  5. Thats a sexy Seo.
  6. 65daysofstatic - Primer
  7. I'm a rig electrician out in the dirty sands of Saudi Arabia.
  8. Its getting a whole slew of new parts and whatnot right now (cause it's back at Turbochargers.com shop) -- 1) TRD Springs (4) 2) TRD Struts (4) 3) HKS Special Edition Turbo Timer 4) ARP Wheel Studs (4 sets of 5) 5) RBF DOT 4 Racing Brake Fluid (2 bottles) 6) Open ended Lug Nuts (4 sets of 5) 7) PowerSlot Rotors (Front & Rear sets) 8 ) Ingalls SS brake lines (Front & Rear sets) 9) TechnaFit SS Clutch line 10) Dezod Endlinks (Front & Rear sets) 11) Front Hotckis Anti-Sway bar 12) Axxis Ultimate Brake pads (Front & Rear sets) 13) Energy Suspension Master Bushing Kit 14) Energy Suspension Motor/Trans Bushing Kit 15) Gates Low-Temp Thermostat 16) Competition Clutch Stage 2 17) Competition Clutch 12 lb. flywheel
  9. Its a blast to drive. Putting down 252whp & 261 wtq.
  10. Hot Metallic Pink > Light Pink Like the wheels though!
  11. Wallace, the car is looking hawt yo! The rims are especially appealing.
  12. Well... Thats what I thought when I first saw it back in 2003. That it was a new Paseo. In related news, the tC and Celica (last one produced) do indeed share the same stock brakes.
  13. Very clean! Whats the bit of metal sticking out below the fog light in the last pic?
  14. From the posts I've read, looks like the people here are "lush" as you say.
  15. lol I love Starlets and Glanzas. Wish I could import one. Wallace is right. It's still a Toyota, and as of two days ago, a boosted Toyota. It's packing a 2.4L VVT-i 4cyl 160bhp/165tqft. I had it dyno'd stock at 140whp/150ftlb atw. That's the Turbonetics T3/T4 50 trim .48 a/r (watercooled) thats going on the 2AZ-FE. The Scion tC shares a lot with the Avensis (which you guys do have)... Rick, when you come down. I'll have to let you go with it... if I have the new clutch in.
