Ashy
    13
Ashy's Achievements
  1. 4 hour drive away, and don't have a car lol plus I'm working long hours so really hard to find time to go anywhere
  2. Would love this car, shame your so far away
  3. Hi guys thinking of getting back into a starlet, I want a well specced one with fairly low mileage. Just waiting for my ep3 type r to sell. Can do a part ex if anyone's intrested. Txt,call or pm 07519891529
  4. hi guys one of my fuse blew on the car today and my boost controller reset(well I thought it did so I started messing with it) now I don't know how to set it. I need to set it at 1 bar on hi mode and 0.7 on low I'm running td04 mapped with greddy emb
  5. It could be just something that's loose in the engine bay mate.I use to hear rattling sounds in low gears turned out I had a few screws in the back ashtray lol.
  6. hi matt it's ash the guy you bought the car off. them wheels aren't enkei or wedsport they are work alloys if you look closely inbetween the spokes you can see some raised writing saying work xd or something like that.the guy I bought the alloys off put them enkei stickers on for some reason lol.
  7. Ok thank you mate
  8. Where did you get yours from mate?I was thinking it could be something like that too but I don't know much about cars.still learning lol. Thanks
  9. Will try that tomorrow.what would I look out for on the dizzy cap and rotor arm?and how do I check timing?thanks
  10. Still having problems with blitz ecu Hi guys I recently bought a blitz ecu for my Glanza at 1st I just plugged it in and started driving.it wasn't running good at all so I plugged it out for a couple of minutes and plugged it back in again and let it idle for about 45 minutes and drove easy for about 100 miles,after this i took it on the motorway and drove the car pretty hard and it was fine but took it out today and at about 5k revs the car judders feels a bit like a misfire then it runs fine again it doesn't do this in 1st gear and sometimes it doesn't do it all. getting really pissed off now.I've recently changed the spark plugs with some basic ngk ones and got some ultra leads aswell my other mods are cat back exhaust and bypassed the boost selonid.it's currently boosting at 0.7 but does creep up to 0.8 and when its cold it creeps upto 0.9 Please help guys getting really frustrated
  11. but these ecus remove fuel cut,so it can't be that can it?unless it's still sorting out the parameters
  12. Yeah I've bypassed the hi lo mode and I'm running standard actuator at the mo it boost up to 0.7 and then creeps up to 0.8 sometimes 0.9 I did let it tick over for about 15 minutes before I drove the car only drove about 10 miles before I started going fast in higher revs
  13. Blitz access ecu and fuel cutHi guys just fitted my blitz access ecu I bought the other day.the other mods on my car is air filter,blitz cat back exhaust and a baileys bov.after I fitted the blitz ecu I bypassed my boost selonoid and took it out for a drive,went on a long stretch at put my foot down in 2nd gear and as I got to about 4k revs it felt as if I was hitting fuel cut.it does this in every gear but not 1st gear. I then unplugged the blitz ecu and plugged it back in again and it stopped the problem.so parked up and left it after about 20 minutes took the car out again and the Same problem happened again so unplugged it and plugged it back in again and it ran fine.what could this be?the boost gauge reads 0.8
