clubman s
    13
About clubman s
  • Birthday 12/03/1976
    Santiago, Chile
clubman s's Achievements
  1. mines is stock used from japan, warm idle is reading 25psi, at 2000rpm+ is 60psi measured with a mechanical gauge
  2. mines read as foll 20psi at 950rpm on a hot engine over 2000- 2500rpm it goes up to 60-65psi using semi sinth oil 10w40Motul
  3. i have a Mini Clubman with a 4EFTE engine swap on it, best desicion ever made!, what a realible engine!!!! done in 2010 runing perfect! http://imgur.com/a/wTNpH
  4. hello, please can you gimme a hand on set it up? need to know wich injectors choose on a TD04L set up, will running a DW pump and with a FMIC cheers AJ
  5. Hi mates! not an EP but a Mini with a 4efte Inside!
  6. ok, i dont have de efi pipe, just a meshed turbo
  7. the mani is correctly ported and woow over 200? ;)
  8. the pictures! the Clubby...... the project.... a lil video
  9. Hi mates got a Mini Clubman with a 4EFTE, with the foll specs CT9 turbo FMIC Blitz Access ECU TRD/Exedy Clutch Cusco LSD TRD spark plug wire set HKS M35i plugs std exh manifold ported no bov or bypass downpipe and exhaust on 2.5" SS and a Borla Turbo rear silencer AEM wideband planing to uprate the psi to 14psi is that posible?
  10. thanks for your help!
  11. Hi Mates anybody knows how to install & wirings for this Rev Limiter? my instruction manual is in Japanese so I can´t do anything Brgds Axel
  12. hi mates I´m Axel from Chile don´t have an Starlet or Glanza V but I Have a Mini Clubman trying to be powered by an 4EFTE engine! cheers
  13. Hi mates can anybody tell me what LSD is that? (brand, 1, 1.5 or 2 way) and all that stufs? and how many torque to the LSD bolts to crownwheel should I Apply? thnks!
