Rossi_Glanza
    47
About Rossi_Glanza
  • Birthday 04/20/1992
    Birmingham
Rossi_Glanza's Achievements
  1. Looking for one without chips but thanks for the offer
  2. As title. OEM crank pulley needed. The one that drives the auxiliary drive belt
  3. Thought I would thanks Colin
  4. How is this done I need to swap con rods over but can work out how to separate them. Any help would be appreciated. Thanks Ross
  5. After 1 4e-fte standard piston. Will buy a set of 4 if needed. Preferably removed from a full working engine. Cash waiting Thanks Ross
  6. Pm sent
  7. Im after the Japspeed insert for the rear silencer if anyone has one Thanks Ross
  8. Only need the wiring loom now, must not be cut up Thanks Ross
  9. As title, im after an alternator as mine has a very noisy bearing Polybush engine mounts, preferably already pressed into mounts but thats not essential Glanza engine loom as i need some plugs Thanks Ross
  10. Thanks dude, ordered a bung of the bay now. Hopefully that would sort it Thanks Ross
  11. Cars runs rich on tickover but when i accelerate it goes lean, i have my lambda sensor plugged in but its not in the exhaust. I cant plug it into the downpipe because my clutch slave cylinder is in the way. Do i need it in the exhaust? Thanks Ross
  12. Yes mate thats the correct plug and it is the wires with the thick connections as you say
  13. As above i need an idle control valve for a Glanza Cash waiting Thanks Ross
