5ecolin
    40
5ecolin's Achievements
  1. the 5efhe box is c152 and is useless on a turbo, gears are way to close just like in 5th @50mph around 2900rpm oo and theres no lsd in them boxes
  2. it will work but wont be perfec
  3. well lads i just got a cynos and want to turbo it i already have the low comp. 5e motor but i dont know wich loom to use i have a ep82 mines ecu that i want to use is the ep82 loom plug and play ? and from the ignition system is it just the igniter coilpak i nead or is there more that i nead if u know of somthing i missed please tell me thanks colin
  4. get some more pics up soon lad its looking interesting
  5. lovly manta your da has now not 2 many around anymore
  6. well lads its working i got a valve from a aircon unit only opens when powered up just wat i wanted but there is a hitch i think i need a pressure release valve or somthing like that between actuator and switch. just that litle snag and we are sorted taken pics so we kan make a sticky in the future on how to operate under boost comments welcom
  7. 5ecolin
    FCD
    do not use fcd there shite they fuck up your engine lad turn your boost dow to 11 12 psi untill u can aford a plug in ecu
  8. well lads im loocking for a 12v airvalve that acepts 5mm vacuum hose haz 2 be closed when not powered on and open when power is suplyed any links or tips welcome
  9. well lads anyone know of a 12v airswitch that takes vacuum sized pipe and that opens when power is suplyed have evrything instaled ecept a open close valve ?
  10. 5ecolin
    GT smoking ?
    no new valve guides?
  11. wired the neo into the mines today and fitted 360cc in jectors just have 2 get the acis working and were of to be set up on the rollers at 1.2 bar almost there just need the acis to work under boost
  12. well lads reversed the spring in the acis actuator and its pulling the chort runners closed and when putting pressure on the actuator it opens is that the right way
  13. thanks guys
  14. how much are thr cruise going for and where
  15. dean there deffo not all the same i now for sure 4efe are thiner coild then the fte 1s
