SKINY Posted March 19, 2016 Posted March 19, 2016 as above folks, i think my problem is with the horn relay now ? how do i test it ? when the relay is out there is power at 1 pin where it has been removed, top right from memory. when the horn is pressed should i get another terminal going live ?? anyone near me fancy swapping there relay in to see ?? Quote
5e colin Posted March 20, 2016 Posted March 20, 2016 take out the relay and put power to it and earth to the other pin now on the 2 others you will see if it opens or not thats how you test it >https://www.youtube.com/watch?v=clSSwXeezDo test if you get power on the horn itselve and if you are getting negative power from the horn button to the relay ( signal ) horn is a real simple setup Quote
SKINY Posted March 20, 2016 Author Posted March 20, 2016 Cheers, will check the other terminal's while pressing the horn. Another one should set the fuse tester off. So simple but so fucking annoying will get a meter tomorrow Quote
SKINY Posted March 22, 2016 Author Posted March 22, 2016 probly should mention the standard wheel with airbag horn didnt work, trd one fitted now. airbag plug has been dealt with but what is the other single yellow plug ?? is that the horn switch wire ?? Quote
