ep82paul Posted March 30, 2016 Share Posted March 30, 2016 Hi everyone need bit of advice my car just started smoking on sunday went to a car meet fine going there but on way home whenever on boost and you let of the pedal it would smoke then it got worse yesterday it smoked on tick over if you revved it it would kick more smoke out I originally thought it was turbo that had gone because there was oil in the intake of turbo but just took manny of with turbo there is no play at all on turbo I put a touch down exhaust ports and they are wet from oil and the valves does that mean stem oil seals have gone any help would great cheers Quote Link to post Share on other sites
starletezy Posted March 30, 2016 Share Posted March 30, 2016 It can be the turbo seals check all the boost pipes for any oil check the compressor housing for any oil while the pipes are off as well also does it puff out smoke randomly on idle? Quote Link to post Share on other sites
ep82paul Posted March 30, 2016 Author Share Posted March 30, 2016 Ye checked boost pipes there is a little bit on the intake side of the turbo pipe like dry oil that's it it does look wet behind the hot side compresser wheel that's why I thought it was turbo because when I took air filter off there was a bit of oil when it started smoking it was only on boost got home yesterday I revved it a little to see the smoke and it started to puff out smoke continously and the smell of burning oil Quote Link to post Share on other sites
Flynn Posted March 30, 2016 Share Posted March 30, 2016 Sounds like mine. But it's not got any worse over time as yours seems to have. Originally thought it was my turbo too but changed that for a reconditioned and tested one Liam had done at midland turbo with no change. Haven't noticed any drop in performance but it's defo burning oil. Will be on the bottom of the dipstick after a couple of months (daily driven). No oil out the exhaust. Coolants all good. Have noticed a small amount of oil has been coming out of the dump valve as there's evidence on underside of the bonnet. I'm thinking stem seals is my issue. Quote Link to post Share on other sites
ep82paul Posted March 30, 2016 Author Share Posted March 30, 2016 cant really get a good picture my phone is shite but so what ya think is dead i took pipe of inlet manifold and there is no oil Quote Link to post Share on other sites
ep82paul Posted March 30, 2016 Author Share Posted March 30, 2016 Quote Link to post Share on other sites
