Lads earlier driving home the car packed it in and died on me, wouldn't start at all got a mate to come up with spare leads and dizzy swapped out the leads no joy and swapped the dizzy and she started up but idle was lumpy we mustn't of set the timing back properly as we were on the side of the road! I'm guessing the dizzy was fooked that I took off ? I changed the cap and rotor recently so were virtually brand new so it's probably the coil is it?
I'd say it's the mechanical part of your dizzy pick up that is fucked put the new cap and rotor onto the dizzy that's running the car,
It's probably running lumpy because ignition timing is out
