sosolid Posted April 3, 2016 Posted April 3, 2016 So its that time. Under the bonnet it shows 10 30 which you cant get, so Ive been using 10 40 semi synthetic castrol magnetec oil, but what oil are others using and would recommend? Quote
sosolid Posted April 3, 2016 Author Posted April 3, 2016 Cool what make is good. FuchS, Mobil, Millers, Gulf, Castrol? Quote
oilman Posted April 4, 2016 Posted April 4, 2016 Hi Is the car standard or modified? Used on track? Cheers Tim Quote
Phil Posted April 4, 2016 Posted April 4, 2016 Let's say modified and used on track for short durations only (2laps then cool)What would you recommend Phil Quote
sosolid Posted April 4, 2016 Author Posted April 4, 2016 (edited) Car is modified. Hybrid ct9 with full supporting mods and ecu running close to 200. Edited April 4, 2016 by sosolid Quote
oilman Posted April 4, 2016 Posted April 4, 2016 Hi In that case, I would use a good 5w-40. http://www.opieoils.co.uk/c-656-5w-40.aspx Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul Sport/300V, Red Line and Gulf Competition. Let's say modified and used on track for short durations only (2laps then cool)What would you recommendPhil Hi Phil Depends on the mods and power, but probably a 5w-40.CheersTim Quote
Phil Posted April 4, 2016 Posted April 4, 2016 Hi In that case, I would use a good 5w-40. http://www.opieoils.co.uk/c-656-5w-40.aspx Out of those, the best ones are the Fuchs/Silkolene Pro S, Millers CFS/CFS NT, Motul Sport/300V, Red Line and Gulf Competition. Hi Phil Depends on the mods and power, but probably a 5w-40.CheersTimThanks what sort of mods would make a difference ? I don't want to start listing random crap that makes no odds to you.Hp probably about 300/330 maybe 370+ the odd time Phil Quote
oilman Posted April 4, 2016 Posted April 4, 2016 Hi Phil Any idea how hot the oil gets on track? Regards Tim Quote
oilman Posted April 5, 2016 Posted April 5, 2016 Hi No, it's fine, it's only thinner than a 10w-40 when cold, so gives better cold start protection. Cheers Tim Quote
sosolid Posted April 5, 2016 Author Posted April 5, 2016 Ok cool and also i dont really do track days and use it on normal roads so those oils ar all good for normal use, yes? Quote
oilman Posted April 5, 2016 Posted April 5, 2016 Hi Yes, they are fine for normal road use. Cheers Tim Quote
