Matty135 Posted April 11, 2016 Posted April 11, 2016 Hi guys, my first post on UKSO because I can't find the resolution to my issue anywhere, either google or forum search. Anyways, as stated my indicators/hazards work, but sometimes the indicators stop working, but the hazards still work no matter what. I have 2 indicator relays, one is probably the one it rolled out of the toyota factory with, and the other is off a fully working 2002 rav4. I have tried swapping them and I still have the same issue. So I'm assuming it's something to do with the signal from the indicator stalk to the relay, or the relay to the lights? I'm pretty clueless when it comes to electronics... any help is appreciated. Just need advice on where to look and what to check etc. Cheers, Matty. Quote
jellybaby Posted April 13, 2016 Posted April 13, 2016 Some timesThe hazard switch can get stuck causing them not to work Quote
Matty135 Posted April 14, 2016 Author Posted April 14, 2016 Thanks for the reply, I guess I shoulda checked that. Just pulled the connector out the back of the hazard switch and plugged it back in, all working now. Quote
jellybaby Posted April 15, 2016 Posted April 15, 2016 No worries alwaysStart with the little things Quote
