nikhilkamdar12 Posted April 16, 2016 Posted April 16, 2016 Hi all, In need of an Glanza plastic cluster surround? If anyone has one lying about they don't need?? Thanks Nikhil
Dale SR Posted April 16, 2016 Posted April 16, 2016 Is is the bit that sits around the speedo clocks your after?
nikhilkamdar12 Posted April 16, 2016 Author Posted April 16, 2016 Is is the bit that sits around the speedo clocks your after? Hi mate, Not the part in the actual housing of the cluster but the main black plastic you have to remove if you want to take your dials out. Cheers Nikhil
Dale SR Posted April 16, 2016 Posted April 16, 2016 Ye that's the bit I thought you wanted I have one £15 posted and it's yours.
