brake upgrade
right basically im putting a 4age in my 98 SR and the standard uk spec brakes were terrible before hand and with the extra weight of the new engine i was looking for something a bit more substantial
so...
after browsing the site doing numerous searches the only real thing i can find is about the levin twinpot upgrade, which has a good fitting guide and pics, which as tempting as it seems is prooving to be kinda akward because finding a set of calipers is near on impossible
the other thing that got a mention was the celica twinpot swap but i cudnt find a fitting guide or any info on wether they actually fit or not!?!
so basically is ther any info on the celica brakes or does anyone no of another set up that might work, baring in mind of the added engine weight and the possibility of some hard use ie trackdays etc.
oh and if it requires any fabrication or machining thats fine i can sort that out
any info and links will be greatly appriciated
cheers morgey
