Yeah once it runs its absolutely spot on with no running issues at all. Were is the fuel pressure reg located? On start up i also get a wiff of fuel as though its over fuelling. Only at start up though.
if its standard it will be on the left hand side of the fuel rail. small silver looking device with fuel line and vacuum line attached.
Is it worth getting an adjustable one? Is it something i can clean out or something to see if this is thecause?
Fuel pressure reg is located on the drivers side on top of the fuel rail I got a few here if you want one mate I would leave the adjusable one alone until the car is tuned
  • 10 months later...
Hi mate, hard to say as havent run the car since, however i have been starting it up and havent noticed it not starting up straight away (Mind has been elsewere due to other concerns) it will be back out this month early next so ill let you know 👍🏼
