mini valver Posted May 8, 2016 Posted May 8, 2016 What cams and duration would be the best to use?? What benefits would the 5efhe cams make?? Has any one had any experience with the speedvision cams and what do people no about using the yaris solid buckets and lifters cheers for any info lads Quote
5e colin Posted May 8, 2016 Posted May 8, 2016 What cams and duration would be the best to use?? What benefits would the 5efhe cams make?? Has any one had any experience with the speedvision cams and what do people no about using the yaris solid buckets and lifters cheers for any info lads to hardcore they are 270 degree intake and 280 out to hardcore 265 is way better with good lift ( im on the hunt to ) Quote
5e colin Posted May 8, 2016 Posted May 8, 2016 (edited) Standard cams are as good as there good ya but holding usuable power locked smal upgrade is better for top end as our engines are not designed for top end cams and 4efte intake are a limiting factor if you like rpm Edited May 8, 2016 by 5e colin Quote
starletezy Posted May 8, 2016 Posted May 8, 2016 You have a fair point there thats my opinion unless you have supporting mods its probably useless going after market cams Quote
5e colin Posted May 8, 2016 Posted May 8, 2016 You have a fair point there thats my opinion unless you have supporting mods its probably useless going after market cams ya 100% agree on ct9 setups but tdo4 and bigger deffo change them Quote
AdamB Posted May 9, 2016 Posted May 9, 2016 If it's a road car = stock cams If it's a race car = depends on setup and what it's actually going to be used for Quote
mini valver Posted May 9, 2016 Author Posted May 9, 2016 Fully forged Custom race tech manifold Trying to get 400bhp I have been told the head strugle to flow after 380ish. Quote
