RandomDan Posted May 14, 2016 Share Posted May 14, 2016 Does anyone know of a good one? Looks like to fucker has let go so i best start looking at getting and replacing it! Quote Link to post Share on other sites
daniel_g Posted May 14, 2016 Share Posted May 14, 2016 Gearbox, clutch kit, flywheel offPoke a hole in the sealPut a screw in the hole and use a driver to pry against it to pop it out (so ya dont damage seal contact surface)Clean up the areaLube the new sealGently and evenly tap the new seal in (i use a 3/8" extension and a hammer)Use new flywheel bolts or loctite the old onesRebuild in reverse orderSorted. Quote Link to post Share on other sites
RandomDan Posted May 14, 2016 Author Share Posted May 14, 2016 On 5/14/2016 at 3:38 PM, daniel_g said: Gearbox, clutch kit, flywheel offPoke a hole in the sealPut a screw in the hole and use a driver to pry against it to pop it out (so ya dont damage seal contact surface)Clean up the areaLube the new sealGently and evenly tap the new seal in (i use a 3/8" extension and a hammer)Use new flywheel bolts or loctite the old onesRebuild in reverse orderSorted. Lol fair enough. So long as there is no special requirements getting the old one out ill be happy.Well not happy but less annoyed doing a shitty job Quote Link to post Share on other sites
