Madge1980 Posted May 18, 2016 Posted May 18, 2016 So I decided to strip the little turbo down to see what all the fuss was about, just have a few questions if anyone can help... can anyone clarify if this is the correct seal kit I need http://m.ebay.co.uk/itm/Turbo-repair-rebuild-kit-CT9-Toyota-Landcruiser-Starlet-Previa-Hiace-Picnic-/222095517834?nav=SEARCHI marked the compressor and turbine wheels before I removed them , but if I fit them even slightly out of balance is it likely to explode the 1st time I use it or should I fit the seals etc and send it to be balanced? Or should I just send the whole unit off for rebuild and who would you guys recommend to do this. Thanks in advance for any help :-) . Quote
SpikeyJp_68 Posted May 18, 2016 Posted May 18, 2016 I personally would send it off to be rebuilt fully. At least you've peace of mind then and it will need balancing anyway Quote
patman Posted May 18, 2016 Posted May 18, 2016 Like in the last post mate wouldn't even bother with this get it sent off Quote
Madge1980 Posted May 18, 2016 Author Posted May 18, 2016 Any recommendations who or where to send it to? Quote
patman Posted May 18, 2016 Posted May 18, 2016 Liam D use to do everyone's on here from midlands turbo, or find him on Facebook under Liam Doyle 👍🏻 Quote
Madge1980 Posted May 18, 2016 Author Posted May 18, 2016 Liam D use to do everyone's on here from midlands turbo, or find him on Facebook under Liam Doyle 👍🏻 Cheers mate I shall send them an email in the morning Quote
