SpikeyJp_68 Posted May 28, 2016 Posted May 28, 2016 (edited) Looking for a standard glanza conrod with matching end cap. Mine are stamped 682MCan't be from a GT as they're thicker and I already have 2. Can swap the GT rods if needed. Located in Ireland Edited May 28, 2016 by SpikeyJp_68
Justforfun Posted May 29, 2016 Posted May 29, 2016 I've an old block there but not sure if it's from a gt or Glanza is there anyway to tell them apart?
SpikeyJp_68 Posted May 29, 2016 Author Posted May 29, 2016 I don't think so from the outside. These are the two rods together
SpikeyJp_68 Posted May 29, 2016 Author Posted May 29, 2016 I've an old block there but not sure if it's from a gt or Glanza is there anyway to tell them apart?PM sent
5e colin Posted May 29, 2016 Posted May 29, 2016 (edited) i have 4 glanza rods ere kid will swap the 4 for your 2 fat gt rods im local ish to you Edited May 29, 2016 by 5e colin
SpikeyJp_68 Posted May 29, 2016 Author Posted May 29, 2016 i have 4 glanza rods ere kid will swap the 4 for your 2 fat gt rods im local ish to you PM on the way
Justforfun Posted June 6, 2016 Posted June 6, 2016 I've 3 here if you don't get any off colin. Will sell separately
SpikeyJp_68 Posted November 25, 2016 Author Posted November 25, 2016 Bump...I was given one but now I've gone to dig it out I can't find it....
5e colin Posted November 25, 2016 Posted November 25, 2016 I have a set here amigo 4 v rods going cheap as I don't ever use them I only use gtt rods pm me
starletezy Posted November 28, 2016 Posted November 28, 2016 Have 3 here from an gt if that helps mate
SpikeyJp_68 Posted November 28, 2016 Author Posted November 28, 2016 (edited) Have 3 here from an gt if that helps mateNo use if from a GT unfortunately. Just got sorted in the past 5 mins. Can be locked if needed Edited November 28, 2016 by SpikeyJp_68
