Cyanidesid Posted May 30, 2016 Posted May 30, 2016 Hey guys and gals I'm about to make a diy short shifter by lengthening the the stick by the bottom by 10mm ! Has anybody had any problems with shifting gears being tight ect !! I know I have to space the between the floor and shifter too Quote
richardc9052 Posted May 30, 2016 Posted May 30, 2016 The Max is whatever your Willing to space your gear lever cradle up. I had to trim the inside of my centre console so it would fit again. If you want to avoid trimming the. Just measure the gap and work from there. Mine was an ep80 Quote
Johnboy GT Posted May 30, 2016 Posted May 30, 2016 I has to knock the tunnel down slightly for mine. Mine is a ECC short shifterJohn Quote
richardc9052 Posted May 31, 2016 Posted May 31, 2016 You could have raised it up with spacers but I suppose that allows extra length if you do both lol Quote
Johnboy GT Posted May 31, 2016 Posted May 31, 2016 It has spacers aswell. It was just 3rd it was catching on.John Quote
