The wiring knock sensor wiring from the end of the injector loom down to the sensor has broken.
Can anyone suggest type of wiring required and best place to get hold of it?
Just just used some 0.5mm screened cable. Just make sure the screen is earthed at one end.
Could only get hold of 2 core but just used one of the cores and the others just sat there not wired in as a spare
Hang on goose I swear you gave me some of that wire you had as I had this problem once and you sent me some if I remember correctly?
Yeah as above, as long as its braided you will be fine. Don't connect the braid to ground at the sensor end though, just connect it to your original braid where it broke off.
