ashep91 Posted June 12, 2016 Posted June 12, 2016 Hi guys looking for a catch can with the fittings preferably but if it hasn't not the end if the world I remember a trader making ones that were a curved shape instead of the usual tube shape if anyone has one
ashep91 Posted June 12, 2016 Author Posted June 12, 2016 Cheers mate I sort of wanted one asap if anyone had one? What's the difference between the ones on eBay and a branded one? Apart from name and quality? Is there a difference performance wise as I thought they only stored excess oil
aleximport25 Posted June 12, 2016 Posted June 12, 2016 The custom ones usually have some form of baffle to help catch the vapours, the biggest thing to look for is to make sure it is vented otherwise it will cause excess pressure in the engine
ashep91 Posted June 12, 2016 Author Posted June 12, 2016 Vented so a filter on top of the can? Does a normal time shape catch can need a baffle
aleximport25 Posted June 12, 2016 Posted June 12, 2016 As long as it's not sealed your fine, the surface area of the vent need to be the equivalent to both of the ports. It doesn't need the baffle you could put some wire wool in to collect the vapours
