EP70-PT Posted June 16, 2016 Posted June 16, 2016 So, as I installed my ITB's, I had to remove the Idle control system and the little 3 pin green sensor thaat was on the old throttle body, my problem is now my idle is hard to fine tune and if I leave it off, the CEL pops on with the idle control code, is there a way to control my idle better without my car dying in the first 10 seconds after starting? already tried the screw on the ITB's and if I go any further it just accelerates to redline ahah, can I trick the ECU without affecting idle? Cheers Quote
5e colin Posted June 16, 2016 Posted June 16, 2016 (edited) think it gose back to your tps sensor not being set right ?? Edited June 16, 2016 by 5e colin Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 could it be that?? How exactly do I set it up?? should I turn it a little more? Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 Nope not that, I also noticed that when I remove the sensor, I get pops through the intake ahah Quote
5e colin Posted June 16, 2016 Posted June 16, 2016 could it be that?? How exactly do I set it up?? should I turn it a little more? multimeter and check ohm reading the wikki is ok tgtturbo,com Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 Could it be my fuel pressure? (Oem reg) or the fact that I'm really low on fuel??? Quote
5e colin Posted June 16, 2016 Posted June 16, 2016 (edited) whats the pressure ??? stock ?? then no cant be the way i see it you either set the tps properly whitin spec OR set your throttle linkages on al bodies to set them al up you know like they do on bike carbs to set equal air flow this has a major inpact on stationary running more info on them tt body balancing here http://joeblogs.eu/2015/08/04/triumph-tt600-throttle-balancing/ have you also checked how much vacuum your getting in your custom vacuum tank might be not enough ? Edited June 16, 2016 by 5e colin Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 (edited) A lot to take into equation then.... how do I check the vaccum?? Edited June 16, 2016 by EP70-PT Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 I'll go to a bike shop to get them balanced, seems to be a pro job... Quote
5e colin Posted June 16, 2016 Posted June 16, 2016 (edited) you need them on the car to do so no not pro job simple if you understand it have a look online for throttle balancing you need to buy throttle balancing tool like this http://www.ebay.co.uk/itm/Yamaha-XJ-750-Seca-1982-1984-Throttle-Balancing-Vacuum-Gauge-4-Dial-Kit-Jmp-1-/141831298409?hash=item2105cddd69:g:9~UAAOSw4UtWTmG7 you can make your own to on the cheap you get the idea here https://www.google.ie/search?q=diy+throttle+balancing+gauge&espv=2&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiI7uzjsK3NAhXoLcAKHeOGCYcQ_AUIBigB&dpr=1 Edited June 16, 2016 by 5e colin Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 Yeah I see what it is, I've been fiddling with the screws for a while but without the tool it's a guess job... Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 A vaccum problem would throw me a code I think Quote
5e colin Posted June 16, 2016 Posted June 16, 2016 no you dont get it it has nothing to do with a vacuum leak it has to do with setup of throttlebodie al 4 need to be the same do some research on throttlebobie setups and how they effect the engine Quote
EP70-PT Posted June 16, 2016 Author Posted June 16, 2016 I get it mate, every throttle needs the same amount of air going through or it won't work, I need to balance them Quote
5e colin Posted June 17, 2016 Posted June 17, 2016 bingo and while you are at it do this to the body first thats connected to the tps just do as they say in the link use the ohm settings to get tps in ints range for the ecu http://www.toyotagtturbo.com/forums/showwiki.php?title=TPS+throttle+position+sensor+set+up+procedure Quote
EP70-PT Posted June 17, 2016 Author Posted June 17, 2016 The first one isn't adjustable, I'll take the car to a bike shop, they'll know what to do ahah Quote
