Ok, when Im pushing hard around a tight corner it seems as though the newly added anti roll bar makes a nasty creeking sound. I am pretty sure it is the anti roll bar as it didn't do it before. However I never really pushed it that hard before it.
It doesn't make the sound If its a long shallow corner, just a tight one say 60 degree or something.
Anyone experiance the same or had this issue and fixed it?
Cheers,
Rich
you really got to grease that baby down GOOD,
otherwise the creeking is gonna be there,
also the bar have to have enough space to move around, the 2 vertical bars going up i mean.
i would say use some spraygrease on the joints.
front or rear?
waht antiroll bar is it?
does it have polyurethane bushings?
Sorry ^^ B)
Rear adjustable whitline one. With poly bushes. Maybe a bit more grease will work. I was just wondering if it was a savere problem. I.E will rip car apart :p
did you put the grease on the inside of the bushings when you fitted it?
if not, thats the noise. itll stop doing it eventually. its just the poly slipping on the roll bar. no biggie.
  • 2 weeks later...
Ok, :(
WD40 evaporates pretty quick dude.Plus its more of a releasing spray..
Anytype of spray thats silicone based is the way to go.
Saying that, i need to cake my coilys in it, theyve started making a damn annoying squeek over bumps :)
Gonna give em a bath in it weekend :(
