http://www.toyotagtturbo.com/forums/showthread.php?105919-Single-Wire-O2-Sensor
that was an older post...not sure if the seller in the link is still active...but worth a try
you can always get a direct fit used one for cheap on here or at the local scrappers
PS---the poster states that you would need to cut and solder your old plug/connector
Edited by gorganl2000
