Breather from block ?
Only breather from the bottom end is contained within the engine/head. The baffle plate in the rocker cover sometimes clogs up restricting the breathing for the engine. Could be worth removing the baffle plate and cleaning it out then refitting it. 👍🏻
So took rocker cover off today baffle seems OK can blow through both breather pipes, did a compression test all roughly 180 so pistons are OK.
  On 7/8/2016 at 4:16 PM, richardc9052 said:
I use the dipstick. Put piping onto the tube with an inline filter and put the dipstick by the fuse box.
Boom. Crankcase breather.
Only small I know but better than none
If you put piping on the dipstick tube with a filter on then the dipstick won't go through ? Edited by turbo-fever
