richardc9052 Posted July 10, 2016 Posted July 10, 2016 Has anyone got access to these? I will be fitting my alarm but havent even looked at the wiring yet. If someone already has the info it would save me a bit of time.I searched the forum but came up empty. Thanks Quote
5e colin Posted July 10, 2016 Posted July 10, 2016 tap your allarm into the orange box unit under steering colum for the central locking !!! open and close is al you need there 2 wires you can either activate with positive or negative depending on alarm types Quote
richardc9052 Posted July 10, 2016 Author Posted July 10, 2016 Yeah I know how it works id just like a diagram. have no bother figuring it out but id rather just go out knowing exactly which wires do what to save time.Have you done it before colin?Plus my alarm is negative Quote
5e colin Posted July 10, 2016 Posted July 10, 2016 yes i have richard plenty of times just use a - dummy wire connect 1 end to chassi and 1 end you pin in the plug theres 4 its the 2 inner 1s just give them a dab of negative to see wichs wire is for open or closed its a reall simple setup in our cars Quote
triple j Posted July 10, 2016 Posted July 10, 2016 Negative trigger it will be, its best splicing it in to the driver door switch loom bottom right of the foot well, I done a few dead handy. Quote
richardc9052 Posted July 10, 2016 Author Posted July 10, 2016 Thanks lads ill give it a shot tomorrow. 1 hour window a day and about 5 hours work left before test. Been a long 10 months lol Quote
