Been thinking about this too.
I have a set of discs and pads sitting here from a megane rs and they are fuckin massive, i duno if theyd even fit under 16" wheels.
Also youd need some sorta bracket to hold the caliper on.
ive been looking for a decent caliper for a bit and i thaught the radial mounted brembos would suit with a made bracket as you can position the caliper exactly where you need it
I done this in the past.
2 things I didn't like about them.
Depending on the wheels you need 10-15mm spacers.
Also i found the brake servo wasn't up to the job causing the pedal to be spongy .
