westie Posted July 28, 2016 Posted July 28, 2016 (edited) As title! I'd like to change the o/s reverse light in the standard rear cluster to a fog light (so it'd be like a uk spec car). I've already got a fog light switch from a uk car, and i'm planning to put it in the stock uk position to the right of the steering wheel. I couldn't find a how to in the guides and tutorials section, anyone help me out?Cheers! Edited July 28, 2016 by westie Quote
daniel_g Posted July 29, 2016 Posted July 29, 2016 You have to splice into the wire around the steering column which gives 12v when the headlights are on. Feed that to the fog switch. Ground the other wire from the switch.Does the standard ep91 switch light up?You need a 'tell tale' for MOT so you might need to use an aftermarket switch. Quote
westie Posted August 2, 2016 Author Posted August 2, 2016 Nice one, cheers Dan. Standard switch unit does light up. Quote
