when i'm booting it i get a high pitch whistling noise from the engine, its only when i'm high revving. it doesn't sound like a air leeking noise and i have check all my pipes etc.. i dont seem to be loosing any power either.
anyone got any ideas??
cheers kyle
BOV leaking mate i would say, mine is the same at really high revs. i put the standard recirc back on and the noise dissapared so i would look at that.
mine didnt sound like its coming from bov but it was
its a suggestion, i wouldnt dismiss it until you have tried. just completely remove the bov and take it for a run. if its still there then you know to look else where.
check belts and pulleys
i have lightweight pulleys and it makes a high pitched whistle noise, not any bother to me though i like it.. :rolleyes:
i run it with out the bov and its still making the noise. its hard to check the belts and pullys, they all seem fine but obviously i cant check them when its making the noise. i doesn't bother me that much because i dont loose any power i'd just like to know what it is.
anyone else got any ideas?
