My osf hub nut seems to be wanting to wind itself loose no matter what I replace. It started doing it several months ago which required me to tediously torque it back up every 100 or so miles. I replaced my cv joint and my front bearing and torqued it back up. But I am still finding that the hub nut is winding loose its even doing to the extent that it is shaving the castleated teeth of with the split pin. I have completely run out of ideas. And I am completely oblivious as to what could be causing this. Any help on this topic would be greatly appreciated.
New nut, thread lock, torque it, fit the biggest split pin possible.
Also knock the side tabs of the nut into the flat parts of the CV with a plain chisel.
