Gainzy Posted August 20, 2016 Posted August 20, 2016 http://www.ukstarletowners.com/topic/77815-epic-find-every-part-number-and-picture-you-will-ever-need/Scrole to the bottom you can buy zep one's on RHD to. Quote
jamesglanza Posted August 20, 2016 Author Posted August 20, 2016 I just need the thread size not the sensor cheers Quote
5e colin Posted August 20, 2016 Posted August 20, 2016 isnt it m16x 1.5 been told its this to so both will work http://www.ebay.co.uk/itm/3-8-18-NPT-HSS-Taper-Pipe-Tap-3-8-18-TPI-Z-NPT-/161527041027?hash=item259bc30c03 Quote
jamesglanza Posted August 20, 2016 Author Posted August 20, 2016 Cheers colin, wasn't sure if it was m14 1.5 or 16 Quote
5e colin Posted August 20, 2016 Posted August 20, 2016 (edited) just checked my bit there for ya its indeed the 1 in the link i provided both threads will work Edited August 20, 2016 by 5e colin Quote
Gainzy Posted August 20, 2016 Posted August 20, 2016 If you look on the link at the packet it tells you Quote
jamesglanza Posted August 20, 2016 Author Posted August 20, 2016 Cheers gainzy didn't scroll all the way to the bottom, oops. Sorted now 👍 Quote
5e colin Posted August 20, 2016 Posted August 20, 2016 If you look on the link at the packet it tells you i cant see shit ??? Quote
