glanza ep91 23 Posted August 21, 2016 Posted August 21, 2016 Im changing the oil pump but how do i remove the crankshaft sprocket without damaging it thanks Quote
Starlet__SR Posted August 21, 2016 Posted August 21, 2016 Im changing the oil pump but how do i remove the crankshaft sprocket without damaging it thanks The sprocket should just slide off, it's clamped by the bottom pulley. Just the woodruff key to keep it located. Quote
