Mike2016 Posted August 27, 2016 Posted August 27, 2016 So I have had a quick look around and can't seem to find anything on the topic does anybody have a wiring diagram for the indicator stalk on a 98 sr. If not does anybody just know which wire is for the sidelights? Thanks in advance Quote
jellybaby Posted August 27, 2016 Posted August 27, 2016 What's the reason for checking ? Have u lost sidelights ? Quote
Mike2016 Posted August 28, 2016 Author Posted August 28, 2016 No I just have illegal sidelights and want to be able to turn them off while driving by adding a switch Quote
jellybaby Posted August 28, 2016 Posted August 28, 2016 You have to have side lights showing when lights are on etc or you willBe asking for trouble. Also in what way are the illegal what colour are they ? Quote
Mike2016 Posted August 29, 2016 Author Posted August 29, 2016 I had no side lights for a while and nobody seemed to notice and they are illegal because they are purple and very noticeable due to using 13 leds per bulb Quote
jellybaby Posted August 29, 2016 Posted August 29, 2016 Ok what u need to do is buy you self some standed to ones for when u have mot. Mean while on the steering colum there be a connector to the light stalk using a multi meter u can locate the correct wire Quote
Mike2016 Posted August 29, 2016 Author Posted August 29, 2016 Fair enough, any advice for getting to the wires/connector or is it just simply remove some screws and pop apart some clips Quote
jellybaby Posted August 29, 2016 Posted August 29, 2016 If you remove theSteering wheel surround should be few screws then pop off the uWill see the connectors to the stalk Quote
Mike2016 Posted August 29, 2016 Author Posted August 29, 2016 Sounds easy enough I'll have a look when I get home from work Quote
Mike2016 Posted August 29, 2016 Author Posted August 29, 2016 Now after messing around with this for a while I have managed to find out which is the sidelight wire. Only problem is I haven't cut any wires or anything and I think I've somehow managed to lose the beam indicator on the clocks. Firstly does an sr have one I'm fairly sure it used to and if so any ideas Quote
Mike2016 Posted September 6, 2016 Author Posted September 6, 2016 Was just a coincidental bulb that had gone all is good Quote
