jjullienn Posted September 12, 2016 Posted September 12, 2016 Hello !I post here on the behalf of a friend. When we drive his ep81 starlet, some engine coolant is going to the expansion tank (approx 5 cm more in the expansion tank). During driving the coolant stays warm (the jauge stays in the middle position). Is it possible that it is due to a faulty radiator cap ?Thanks ! Quote
akyakapotter Posted September 12, 2016 Posted September 12, 2016 Some coolant may be pushed into the expansion tank it will suck it back into the system when it needs it. I wouldnt worry about it. Quote
starletezy Posted September 12, 2016 Posted September 12, 2016 Wouldnt worry about it unless the expansion tank is over flowing or bubbling its normal for the water to sit halfway or abit over Quote
Starlet__SR Posted September 12, 2016 Posted September 12, 2016 It's doing what its designed to do, expelling excess coolant due to thermal expansion. If it's boiling the fluid thats when you have issues. Quote
