EP70-PT Posted September 23, 2016 Posted September 23, 2016 What I said... I'm tired of this sh... Even my tacho needle goes up when I turn my key without even starting the engine... Heeeelp Quote
nikhilkamdar12 Posted September 23, 2016 Posted September 23, 2016 Check all your grounds. Stange things can happen if you have poor grounds!! Quote
EP70-PT Posted September 23, 2016 Author Posted September 23, 2016 Not the grounds.... I should maybe say that my battery is low (7v), can it be a relay?? Quote
Pete_A Posted September 23, 2016 Posted September 23, 2016 Do your lights work with indicators? Lights r a fuse, indicators a relay, so bad earth under the bonnet? Quote
EP70-PT Posted September 23, 2016 Author Posted September 23, 2016 They won't work with indicators...the earths are fine.. Quote
