turbominicooper Posted September 27, 2016 Posted September 27, 2016 my hunch is this is the stalk not engaging properly but here goes... my indicators do not flash they just illuminate to the direction I point them (L & R). I thought at first it was the relay playing up and was going to ask where it was located behind the dash but last night when I had it on I pressed the direction a little harder (either L or R) and then it began to flash but a very slow flash?? so what do you think faulty stalks or faulty relay? Quote
t'mill Posted March 30, 2017 Posted March 30, 2017 Where is the relay located on a Sportif model? I'm going to try LED bulbs so need to change the relay to correct the flash rate Quote
turbominicooper Posted April 18, 2017 Author Posted April 18, 2017 My flasher relay was next to the steering column. You could always get a torch and look Quote
t'mill Posted April 24, 2017 Posted April 24, 2017 (edited) My flasher relay was next to the steering column. You could always get a torch and lookDid you take the lower dash plastics off to get to the relay?? I had the lower plastics off yesterday (upgrading the speakers) but couldn't see a relay anywhere Edited April 24, 2017 by t'mill Quote
t'mill Posted May 11, 2017 Posted May 11, 2017 Did you take the lower dash plastics off to get to the relay?? I had the lower plastics off yesterday (upgrading the speakers) but couldn't see a relay anywhereBumpIn had the dash clocks plastic binnacle off yesterday and still couldn't see a relay despite the hazards being on to locate where the clicking was coming from. Could someone give me a definite location for the indicator relay please? Quote
