Just done a quick search bud first one a came across gave this hope if helps do a quick search with the form you'll find every thing you need cheers nick :)
isn't a big job as Richard said
parts you will need
full loom dash and engine
exhaust system
turbo and manifold
cat
intercooler and pipe work
knock sensor check your block first if you have the hole or ya will need to drill it to fit the knock sensor
thermostat housing as has extra feeds for running water through turbo not essential but if ya can get it fit it
injectors
sump with oil feed return
throttle body as turbo ones are slightly bigger or if ya can get a full inlet get it
map sensor
fuel pump starlet one doesn't flow fast enough
boost gauge again not essential but handy to know what boost your at
rocker cover has extra crank case breather
ecu
standard actuator make sure ya get hi low boost button and run it on low boost
probably bits im leaving out but ya get the jist of what parts ya need gearbox side of things your box should do the job ya might need to use your flywheel and clutch setup
