Just remove the plastic that the loom sits in, unplug the injectors and then feed the loom under the inlet and pull the plugs through the gap between runner 2 and 3. the only thing you might need to extend is the plug for the ICV. Turn the injectors gently without pulling them out so that the plugs face the inlet. I wrapped the loom in High temp waterproof PVC for a bit of protection but more to keep all the wires together and tidy. I also put a thin wrap of yellow pvc on the wires for injector 2 and 4 to differentiate them from 1 and 3.
