Hello lads please could someone point me in the right direction here, I took my cluster out today, (was just checking the wires to the water temp gauge) as the needle has started bouncing about, anyway as I put the plugs at the back, back into the cluster, there was suddenly alittle bit of smoke, to cut the story short everything works on the cluster apart from the 3 main bulbs what light it up, I have checked fuses and the fuse for the cluster bulbs and everything seems fine, all headlight, tail light, brake lights etc are working ok, it's just the cluster 3 bulbs which is now confusing me,
Is there something I missing here please? Or something I have not checked, I even swapped the fuse too just to see and still no dash lights
Seems like with the little bit of smoke something has shortened, but there are no loose wires I can see behind the cluster, if anyone has any suggestions please let me know.
Thanks pat
Edited by patman
