Amjad Posted October 24, 2016 Posted October 24, 2016 Hey guys, Does anyone know the best way to remove tigerseal from fibreglass? Bought a set of used wide wings, and the lower areas have old residue from where arch trim/sideskirts were fitted before. Any ideas? Thanks Amjad Quote
akyakapotter Posted October 24, 2016 Posted October 24, 2016 I dont no about fiberglass but I used pertol on a rag on my metal body work when I took my livesports skirts off. Quote
Amjad Posted October 24, 2016 Author Posted October 24, 2016 I assumed petrol would work but I was warned to be careful on fibreglass (never worked with fibreglass so I have no idea?)I removed the OEM glue off my original arches the same way, but I think that glue is a lot milder too Quote
Amjad Posted October 24, 2016 Author Posted October 24, 2016 Ah didn't think of that, thanks Idrees! Any ideas of what I can use to fit my arch trims back on, that isn't as hardcore as Tigerseal? Quote
starletezy Posted October 24, 2016 Posted October 24, 2016 I used double sided tape to stick my arch trims back on worked good make sure its proper automotive stuff Quote
Amjad Posted October 24, 2016 Author Posted October 24, 2016 Didn't think that would be strong enough, I'll check it out thanks! Quote
starletezy Posted October 25, 2016 Posted October 25, 2016 You just need to use the right type of tape most are cheaply made mine sits solid Quote
Amjad Posted October 25, 2016 Author Posted October 25, 2016 Don't suppose you'd have a link? Seen online that a specific type of 3m is very strong, but it's like £60/roll! Quote
